Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 16 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
3. Schritt
Peeling up yellow tape as necessary, remove the following 8 screws:
  • Peeling up yellow tape as necessary, remove the following 8 screws:
  • One 4.5 mm Phillips on the right side of the heat sink.
  • Three 6 mm Phillips near the display.
  • Two large 7.5 mm Phillips with springs (don't forget to remove the springs). If the springs are not releasing, needle nose pliers can help get this done.
  • Two 13 mm screws from the left side of the heat sink and the right side of the fan.
Hier Übersetzung einfügen
