Englisch
Deutsch
Schritt 5 übersetzen
5. Schritt
Pull the tail end of the thread until both threads are equal in length. Holding both lengths of thread together, tie a knot near the end and pull it tight. This will trap the needle in the loop of thread and allow you to sew with doubled thread. If you prefer to sew with a single thread, tie a knot in only one of the threads, not both.
  • Pull the tail end of the thread until both threads are equal in length.
  • Holding both lengths of thread together, tie a knot near the end and pull it tight.
  • This will trap the needle in the loop of thread and allow you to sew with doubled thread. If you prefer to sew with a single thread, tie a knot in only one of the threads, not both.
Ziehe das Fadenende genauso lang wie den einlaufenden Faden durch die Nadel.
Verknote die beiden Enden.
Diese Vorgehen hält die Nadel so im Faden fest, dass du mit einem Doppelfaden nähen kannst. Wenn du lieber mit einem Einfachfaden nähen willst verknote nur eines der Enden.
