Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
5. Schritt
Continue sewing through both layers, going down from the top and up from the bottom, as described in steps 3 and 4 of this guide. When you come to the end of your material, draw the needle in between the two layers of material, under the thread of the closest stitch. Slowly start to pull the thread taut. As you pull a loop will form.
  • Continue sewing through both layers, going down from the top and up from the bottom, as described in steps 3 and 4 of this guide.
  • When you come to the end of your material, draw the needle in between the two layers of material, under the thread of the closest stitch.
  • Slowly start to pull the thread taut. As you pull a loop will form.
  • Draw the needle through the loop and pull the thread taut.
  • Repeat the process of drawing the needle between the layers, creating a loop, and drawing the needle through the loop as described in this step.
Hier Übersetzung einfügen
