Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 6
Using a spudger, separate the bottom panel from the rear case just enough to clear the two clips on the rear casing in the next step. Using a spudger, separate the bottom panel from the rear case just enough to clear the two clips on the rear casing in the next step. Using a spudger, separate the bottom panel from the rear case just enough to clear the two clips on the rear casing in the next step.
  • Using a spudger, separate the bottom panel from the rear case just enough to clear the two clips on the rear casing in the next step.
Hier Übersetzung einfügen
