Englisch
Deutsch
2. Schritt
Spray the connection of the hard brake line and the soft rubber brake hose with penetrating lubricant. This is a good time to consider also changing the soft rubber brake hose since it will already be halfway disconnected and the fluid drained. For more on this, and for more tips on disconnecting the hard lines from the rubber hose, see the rubber brake hose replacement guide. This is a good time to consider also changing the soft rubber brake hose since it will already be halfway disconnected and the fluid drained. For more on this, and for more tips on disconnecting the hard lines from the rubber hose, see the rubber brake hose replacement guide.
accurate link to the referenced rubber brake hose guide
  • Spray the connection of the hard brake line and the soft rubber brake hose with penetrating lubricant.
  • This is a good time to consider also changing the soft rubber brake hose since it will already be halfway disconnected and the fluid drained. For more on this, and for more tips on disconnecting the hard lines from the rubber hose, see the rubber brake hose replacement guide.
Hier Übersetzung einfügen
