Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
You will need to remove your wheels before you start. Before beginning on removal of the calipers you should drain the brake fluid from them.
Drain the brake fluid
  • You will need to remove your wheels before you start.
  • Before beginning on removal of the calipers you should drain the brake fluid from them.
  • This is done through the bleed screw on each caliper.
  • Loosen this and let it drain in to a proper drain pan.
Hier Übersetzung einfügen
