Englisch
Deutsch
2. Schritt
Next you will need to remove the soft rubber brake hoses. You will have to start by disconnecting the rubber hose from the hard line connection up inside the fender well. Then you can loosen it from the caliper and remove the line. This takes a 14mm wrench for the soft hose and an 11 mm wrench for the brake line.
Remove the rubber hoses
  • Next you will need to remove the soft rubber brake hoses.
  • You will have to start by disconnecting the rubber hose from the hard line connection up inside the fender well. Then you can loosen it from the caliper and remove the line. This takes a 14mm wrench for the soft hose and an 11 mm wrench for the brake line.
  • For more information and tips on removing these lines, [Ungültiger Anleitungslink]
  • Speaking of the rubber hoses, this is a great time to replace them with new parts if they show signs of age since they are already off of the car.
Hier Übersetzung einfügen
