Englisch
Deutsch
3. Schritt
Next use a large ratchet wrench with a 19mm socket to remove the two bolts that hold the caliper to the vehicle.
Remove the calipers
  • Next use a large ratchet wrench with a 19mm socket to remove the two bolts that hold the caliper to the vehicle.
  • These bolts are in very tight, and had thread locker on them from the factory, so you may need a very long wrench or a breaker bar in order to get enough leverage to remove these two bolts.
  • Hold on to the caliper as you remove the second of the two bolts so it doesn't fall when you remove the bolt.
Hier Übersetzung einfügen
