Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 5
After you've used the heatgun, you want to start by separating the edges of the glass from the rest of the phone, starting from the top. I used a metal spudger initially, if you're going to use a metal spudger as well you want to be careful to not damage anything.
  • After you've used the heatgun, you want to start by separating the edges of the glass from the rest of the phone, starting from the top.
  • I used a metal spudger initially, if you're going to use a metal spudger as well you want to be careful to not damage anything.
Wenn du mit Erhitzen fertig bist, trennst du von oben beginnend die Ränder der Glasscheibe vom Display.
Das kann man erstmal mit einem Metallhebel machen, aber pass auf, dass du dabei nichts zerkratzt.
