Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
3. Schritt
To remove the motor and trigger mechanism you have to detach these two wires which are glued to the shell. Hold close to the wire and pull upward slowly. If you pull too quickly you can potentially damage the wire.
  • To remove the motor and trigger mechanism you have to detach these two wires which are glued to the shell.
  • Hold close to the wire and pull upward slowly.
  • If you pull too quickly you can potentially damage the wire.
Hier Übersetzung einfügen
