Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 11 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 4
With one spudger, work your way along the right edge of the iPad. The front panel is held to the aluminum back by metal clips on the top, bottom, and left sides.  The right side has plastic tabs which slide into recesses in the backplate.
  • With one spudger, work your way along the right edge of the iPad.
  • The front panel is held to the aluminum back by metal clips on the top, bottom, and left sides. The right side has plastic tabs which slide into recesses in the backplate.
  • Once the clips are released, lift the left side of the front panel up and slide it to the left to clear the tabs from the aluminum backplate.
  • Pry carefully and gently—if you feel resistance, stop and pry at another spot.
Arbeite dich mit einem Spudger an der rechten Kante des iPads entlang.
Die Frontplatte wird durch Metallklammern oben, unten und links am Aluminiumrücken gehalten. Die rechte Seite hat Plastiklaschen, die in Aussparungen in der Rückplatte gleiten.
Sobald die Clips gelöst sind, hebe die linke Seite der Frontplatte nach oben und schiebe sie nach links, um die Laschen von der Aluminium-Rückplatte zu entfernen.
[* black] With one spudger, work your way along the right edge of the iPad.
[* black] The front panel is held to the aluminum back by metal clips on the top, bottom, and left sides. The right side has plastic tabs which slide into recesses in the backplate.
[* black] Once the clips are released, lift the left side of the front panel up and slide it to the left to clear the tabs from the aluminum backplate.
[* icon_caution] Pry carefully and gently—if you feel resistance, stop and pry at another spot.
