Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2 übersetzen
2. Schritt
Simply remove the bottom panel by prying it off with your finger. When removing the panel, be sure the bottom of the camera is facing upright.  There are loose gears that may fall out. Be wary of a loose piece of foam attached to the bottom panel.
  • Simply remove the bottom panel by prying it off with your finger.
  • When removing the panel, be sure the bottom of the camera is facing upright. There are loose gears that may fall out.
  • Be wary of a loose piece of foam attached to the bottom panel.
Hier Übersetzung einfügen
