Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 11 Anleitungen, die diese beinhalten.
Englisch
Deutsch
2. Schritt
In this guide you will be prying the iPad's display assembly away from the aluminum body. Read ahead and follow the directions closely to avoid damaging the display assembly or the fragile clips holding it in place. There are 14 metal clips holding the display assembly in place, shown at left. As you pry in the following steps, do your best to pry around these clips and not slice through them with your opening tool.
  • In this guide you will be prying the iPad's display assembly away from the aluminum body. Read ahead and follow the directions closely to avoid damaging the display assembly or the fragile clips holding it in place.
  • There are 14 metal clips holding the display assembly in place, shown at left. As you pry in the following steps, do your best to pry around these clips and not slice through them with your opening tool.
  • If you do happen to break some clips, you can buy replacements here.
Hier Übersetzung einfügen
[* icon_caution] In this guide you will be prying the iPad's display assembly away from the aluminum body. Read ahead and follow the directions closely to avoid damaging the display assembly or the fragile clips holding it in place.
[* black] There are 14 metal clips holding the display assembly in place, shown at left. As you pry in the following steps, do your best to pry ''around'' these clips and not slice ''through'' them with your opening tool.
[* icon_note] If you do happen to break some clips, you can buy replacements [product|IF180-008|here|new_window=true].
