Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
3. Schritt
With the rifle barrel pointing left, remove the two 8mm phillips screws holding the slide mechanism together. Remove the three 10 mm phillips screws from the bottom of the slide mechanism. Separate and remove the two halves of the slide mechanism.
Slide Removal
  • With the rifle barrel pointing left, remove the two 8mm phillips screws holding the slide mechanism together.
  • Remove the three 10 mm phillips screws from the bottom of the slide mechanism.
  • Separate and remove the two halves of the slide mechanism.
  • Make sure to keep track of which screws correspond to which holes.
Hier Übersetzung einfügen
