Englisch
Deutsch
8. Schritt
In this step, you will heat and remove the plastic frame near the digitizer cable. Do not directly heat this ribbon cable, as it is extremely thin and sensitive to heat. Use a heat gun to soften the adhesive next to both sides of the digitizer cable, being careful not to melt the cable.
  • In this step, you will heat and remove the plastic frame near the digitizer cable. Do not directly heat this ribbon cable, as it is extremely thin and sensitive to heat.
  • Use a heat gun to soften the adhesive next to both sides of the digitizer cable, being careful not to melt the cable.
  • Pry the final section of the plastic display frame away from the front glass.
Hier Übersetzung einfügen
