Englisch
Deutsch
5. Schritt
Lightly heat the rubber connection area. Use a plastic opening tool to separate the plastic display frame from the front glass panel enough to access the rubber area.
  • Lightly heat the rubber connection area. Use a plastic opening tool to separate the plastic display frame from the front glass panel enough to access the rubber area.
  • While holding the display frame away from the front glass, use a razor blade to carefully cut through the many rubber "dots" attaching the frame to the front panel.
  • The razor blade may scratch the black painted border off the inside of the glass panel. If you are reusing your front glass panel, try not to scratch the glass while cutting. Also, to prevent cosmetic damage, avoid cutting through the outer rubber strip.
Hier Übersetzung einfügen
