Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 5
Repeat to remove the second adhesive strip. If you removed both strips successfully, skip the next two steps. If either of the adhesive strips break underneath the battery and cannot be retrieved, try to remove the remaining strip, and then proceed to the next step.
  • Repeat to remove the second adhesive strip.
  • If you removed both strips successfully, skip the next two steps.
  • If either of the adhesive strips break underneath the battery and cannot be retrieved, try to remove the remaining strip, and then proceed to the next step.
Ziehe den äußeren Akku Klebestreifen gerade und vorsichting um die Ecke des Akkus herum.
Ziehe den Streifen entlang der Kante des Akkus, bis er sich vom Mobiltelefon löst.
[* black] PullRepeat to remove the outside batterysecond adhesive tab straight up and carefully around the corner of the batterystrip.
[* black] PullIf you removed both strips successfully, skip the strip along the edgenext two steps.
[* icon_caution] If either
of the adhesive strips break underneath the battery until it is freed fromand cannot be retrieved, try to remove the remaining strip, and then proceed to the phonenext step.
