Englisch
Deutsch
15. Schritt
Insert the cut/stripped speaker wires on each side and use a Philips #2 screwdriver to secure them in place. Make sure you connect the Positive wire to the Positive terminal, and the Negative wire to the Negative terminal. Make sure you connect the Positive wire to the Positive terminal, and the Negative wire to the Negative terminal.
  • Insert the cut/stripped speaker wires on each side and use a Philips #2 screwdriver to secure them in place.
  • Make sure you connect the Positive wire to the Positive terminal, and the Negative wire to the Negative terminal.
Hier Übersetzung einfügen
