Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
2. Schritt
Remove the two cables on the motherboard by grasping the cables with your hand and pulling the cables up and out.
  • Remove the two cables on the motherboard by grasping the cables with your hand and pulling the cables up and out.
  • Repeat the same process to remove the internal card power cable.
  • This is the same process as preformed when you previously removed the power cables from the optical drive and the hard drive.
  • Some cables may have small clips securing them in place. If so, be sure to press these clips inward using your fingers before pulling them out.
Hier Übersetzung einfügen
