Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Flip the projector right-side up and turn it so that the back ports are facing you. Remove the 7mm metallic hex screws using the flat-head screwdriver. Remove the two black 10mm screws using the T10 Torx screwdriver head. The screws are located at the center of the back panel.
  • Flip the projector right-side up and turn it so that the back ports are facing you.
  • Remove the 7mm metallic hex screws using the flat-head screwdriver.
  • Remove the two black 10mm screws using the T10 Torx screwdriver head. The screws are located at the center of the back panel.
Hier Übersetzung einfügen
