Englisch
Deutsch
2. Schritt
Remove the two screws holding the sub-assembly together. Then use the blunt forceps to grab the 2 inch black plastic connector labeled in the picture with the red box. Use the blunt forceps to grab the 2 inch white piece of plastic labeled with the orange box. Use the blunt forceps to grab the 2 inch white piece of plastic labeled with the orange box.
  • Remove the two screws holding the sub-assembly together. Then use the blunt forceps to grab the 2 inch black plastic connector labeled in the picture with the red box.
  • Use the blunt forceps to grab the 2 inch white piece of plastic labeled with the orange box.
Löse die beiden Schrauben die die Untereinheit befestigen. Hole dann mit einer stumpfen Pinzette die schwarze 6 cm Plastikverbindung heraus, im Foto rot markiert.
Hole genauso das weiße 6 cm Plastikteil heraus, im Foto orange markiert.
