Englisch
Deutsch
3. Schritt
With the clear piece of plastic pushed in, take the transparent white piece out from the top of the controller. Keep the clear plastic piece on the controller, but keep it pushed down to provide room for charger port replacement. Use the Philips #00 Screwdriver to unscrew the two 4.0 mm screws that attach the charging port to the rear cover.
  • With the clear piece of plastic pushed in, take the transparent white piece out from the top of the controller.
  • Keep the clear plastic piece on the controller, but keep it pushed down to provide room for charger port replacement.
  • Use the Philips #00 Screwdriver to unscrew the two 4.0 mm screws that attach the charging port to the rear cover.
Drücke das durchsichtige weiße Plastikfenster nach innen und nimm es vom oberen Rand des Controllers weg.
Lasse das durchsichtige Plastikteil im Controller drin, schiebe es nur soweit zur Seite um Platz für den Austausch der Ladebuchse zu haben.
Drehe die beiden 4 mm PH00 Schrauben heraus, die die Ladebuchse an der unteren Gehäusehälfte befestigen.
