Englisch
Deutsch
5. Schritt
Set your soldering iron to a medium to hot setting to adequately melt the solder joints Once the soldering iron is hot enough, touch the tip to the solder joint on the PCB while using tweezers to clear out a big enough hole to pull out the jack Remove the jack once the joints are broken and clean out excess solder
  • Set your soldering iron to a medium to hot setting to adequately melt the solder joints
  • Once the soldering iron is hot enough, touch the tip to the solder joint on the PCB while using tweezers to clear out a big enough hole to pull out the jack
  • Remove the jack once the joints are broken and clean out excess solder
Hier Übersetzung einfügen
