Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Orient the Xbox so the bottom body is facing upwards. Make sure you see the rubber feet to know you have the correct side of the device. Lift the bottom body slightly away from the core at a 45 degree angle. Lift the bottom body slightly away from the core at a 45 degree angle.
  • Orient the Xbox so the bottom body is facing upwards. Make sure you see the rubber feet to know you have the correct side of the device.
  • Lift the bottom body slightly away from the core at a 45 degree angle.
Hier Übersetzung einfügen
