Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Be careful when removing the bottom panel. The plastic tab that runs alongside the right speaker between the upper brown radio motherboard and the lower green audio daughterboard may damage the device if the bottom panel is removed improperly. Remove the bottom panel of the boombox by carefully pulling the  panel straight backwards from the boombox until the boards are free. Remove the bottom panel of the boombox by carefully pulling the  panel straight backwards from the boombox until the boards are free.
  • Be careful when removing the bottom panel. The plastic tab that runs alongside the right speaker between the upper brown radio motherboard and the lower green audio daughterboard may damage the device if the bottom panel is removed improperly.
  • Remove the bottom panel of the boombox by carefully pulling the panel straight backwards from the boombox until the boards are free.
Hier Übersetzung einfügen
