Zum Hauptinhalt wechseln
Englisch
Deutsch
Step 2
Before removing the hoses, the brake fluid on that caliper should be allowed to drain. This is done through the bleed screw on each caliper. The following bleed screws are shown: Front caliper bleed screw
  • Before removing the hoses, the brake fluid on that caliper should be allowed to drain.
  • This is done through the bleed screw on each caliper. The following bleed screws are shown:
  • Front caliper bleed screw
  • Rear caliper bleed screw
  • Allow the fluid to drain by loosening the screw just two or three turns until the fluid is dripping quickly. Use a 9mm box end wrench for this job.
Hier Übersetzung einfügen
