Englisch
Deutsch
Schritt 10 übersetzen
10. Schritt
Then simply remove the now cut lower portion of the hose.
  • Then simply remove the now cut lower portion of the hose.
  • Please be aware that if you are forced to resort to using vice grips to hold the small upper 11mm nut on the hard line to remove the soft line you will then need to replace the hard line as well.
  • After installing the new hoses you must bleed your brake system to remove air. Never drive the car without bleeding it. See the brake bleeding guide.
Hier Übersetzung einfügen
