Englisch
Deutsch
7. Schritt
The switch mechanism disassembly removes the button attached to the lid (red circle) from the grooves (blue circle) containing the switch components. Next, remove the spring first and then metallic, grooved pressure plate which contained the spring (red circle) using hand. Finally, remove metal connections of battery switch by lifting holes (red circle) off containment piece.
  • The switch mechanism disassembly removes the button attached to the lid (red circle) from the grooves (blue circle) containing the switch components.
  • Next, remove the spring first and then metallic, grooved pressure plate which contained the spring (red circle) using hand.
  • Finally, remove metal connections of battery switch by lifting holes (red circle) off containment piece.
Hier Übersetzung einfügen
