Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 10
Remove the 8mm Phillips #1 screw located just below the large gray wire. Remove the 8mm Phillips #1 screw located to the right of the left-hand speaker. Remove the 4mm Phillips #1 screw located above the fan and next to the large gray wire.
  • Remove the 8mm Phillips #1 screw located just below the large gray wire.
  • Remove the 8mm Phillips #1 screw located to the right of the left-hand speaker.
  • Remove the 4mm Phillips #1 screw located above the fan and next to the large gray wire.
Hier Übersetzung einfügen
