Englisch
Deutsch
12. Schritt
Flip the logic board up toward the volume control buttons to expose the antenna connector. Do not try to remove the logic board from the rear case yet, as it is still connected by an antenna cable on the back.
  • Flip the logic board up toward the volume control buttons to expose the antenna connector.
  • Do not try to remove the logic board from the rear case yet, as it is still connected by an antenna cable on the back.
Klappe das Logic Board nach oben Richtung der Lautstärkeregelungsktasten, um den Antennenstecker freizulegen.
Versuche noch nicht das Logic Board vom hinteren Gehäuse zu entfernen, da es noch durch das Antennenkabel auf der Rückseite verbunden ist.
