Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
2. Schritt
To access the screw under the black speaker rumble/assembly, you will need to pry the assembly up slightly using the spudger. The assembly is glued to the back of the screen, so the assembly may not move at first.  Be patient and careful.  Do not pry too hard, or you may break the assembly.
  • To access the screw under the black speaker rumble/assembly, you will need to pry the assembly up slightly using the spudger.
  • The assembly is glued to the back of the screen, so the assembly may not move at first. Be patient and careful. Do not pry too hard, or you may break the assembly.
Hier Übersetzung einfügen
