Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 14 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 9
Lifting from the side nearest the battery, rotate the logic board toward the top of the MacBook Pro. You may need to slide the logic board a few millimeters to the left in order to get clearance for the ports along the right edge of the board.
  • Lifting from the side nearest the battery, rotate the logic board toward the top of the MacBook Pro.
  • You may need to slide the logic board a few millimeters to the left in order to get clearance for the ports along the right edge of the board.
  • Using the flat end of a spudger, carefully push the MagSafe 2 connector out of its socket on the bottom of the logic board.
  • Disconnecting the MagSafe 2 connector can be difficult. If you are only removing the logic board to temporarily get it out of the way, such as for a battery replacement, you may find it easier to simply remove the two 2.5 mm T5 Torx screws securing the MagSafe DC-In board, and then remove the logic board and MagSafe board together.
Hebe das Logic Board an der Seite an, die dem Akku am nächsten liegt und drehe es nach oben.
Eventuell musst du das Logic Board ein paar Millimeter nach links schieben, um die Ports entlang der rechten Kante des Boards freizuhalten.
Drücke den MagSafe 2-Stecker vorsichtig mit dem flachen Ende eines Spudgers aus seiner Buchse auf der Unterseite des Logic Boards.
[* black] Lifting from the side nearest the battery, rotate the logic board toward the top of the MacBook Pro.
[* icon_note] You may need to slide the logic board a few millimeters to the left in order to get clearance for the ports along the right edge of the board.
[* black] Using the flat end of a spudger, carefully push the MagSafe 2 connector out of its socket on the bottom of the logic board.
[* icon_note] Disconnecting the MagSafe 2 connector can be difficult. If you are only removing the logic board to temporarily get it out of the way, such as for a battery replacement, you may find it easier to simply [https://d3nevzfk7ii3be.cloudfront.net/igi/GOcrO3AMpJXvKgv2|remove the two 2.5 mm T5 Torx screws securing the MagSafe DC-In board|new_window=true], and then remove the logic board and MagSafe board together.
