Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
Schritt 5 übersetzen
5. Schritt
Insert the Spudger into the slot on the top of the logic board. Gently pry to loosen the top of the logic board. Note: The logic board may initially seem glued to the phone. It is not glued but does require input of force to remove.
  • Insert the Spudger into the slot on the top of the logic board.
  • Gently pry to loosen the top of the logic board.
  • Note: The logic board may initially seem glued to the phone. It is not glued but does require input of force to remove.
  • Grab the top of the logic board and pull at an angle to remove.
Hier Übersetzung einfügen
