Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
To get to the maelstrom wiring you must first pull off the plastic cover. To do this roll the maelstrom over so the rubber cover on the back is facing up. The rubber pad simply peels off exposing the metal backplate. Then remove the four 8.5mm screws on the back plate of the maelstrom.
  • To get to the maelstrom wiring you must first pull off the plastic cover.
  • To do this roll the maelstrom over so the rubber cover on the back is facing up. The rubber pad simply peels off exposing the metal backplate.
  • Then remove the four 8.5mm screws on the back plate of the maelstrom.
Hier Übersetzung einfügen
