Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
5. Schritt
Remove the screw located below the multi-connector cover using a Phillips #00 screwdriver. Remove the two screws located at the bottom of the camera using a Phillips #00 screwdriver. Remove the screw inside of the battery and card compartment cover using a Phillips #00 screwdriver.
  • Remove the screw located below the multi-connector cover using a Phillips #00 screwdriver.
  • Remove the two screws located at the bottom of the camera using a Phillips #00 screwdriver.
  • Remove the screw inside of the battery and card compartment cover using a Phillips #00 screwdriver.
  • You will first have to open the compartment cover in order to expose the screw located inside of the battery and card compartment.
Hier Übersetzung einfügen
