Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
2. Schritt
Starting at the top of the phone, carefully insert plastic opening device into the seam. Carefully slide device along the seam and around the corners of the phone until the back is separated from the front. Note: Some force must be exerted. Be careful when taking off panel. Go slow.
  • Starting at the top of the phone, carefully insert plastic opening device into the seam.
  • Carefully slide device along the seam and around the corners of the phone until the back is separated from the front.
  • Note: Some force must be exerted. Be careful when taking off panel. Go slow.
  • Note: The volume button may separate from the case, this is normal. It is not broken.
Hier Übersetzung einfügen
