Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Use a spudger or a flat-blade screwdriver to unlatch the plastic screw cover residing within the door pull handle. Move the plastic cover out of the way so that the Phillips screw is fully revealed. Use a #2 Phillips screwdriver to unscrew the screw residing underneath the plastic cover.
  • Use a spudger or a flat-blade screwdriver to unlatch the plastic screw cover residing within the door pull handle.
  • Move the plastic cover out of the way so that the Phillips screw is fully revealed.
  • Use a #2 Phillips screwdriver to unscrew the screw residing underneath the plastic cover.
Hier Übersetzung einfügen
