Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
3. Schritt
There are several retaining clips holding the door panel in place. Their locations are roughly outlined by the red circles. You’ll find a notch in the door panel on the bottom of the door. This is where you should insert your door panel pry tool. You can also use a couple of flat-blade screwdrivers or a paint scraper in lieu of of a door panel pry tool, but you may accidentally damage your door panel’s paint. Optional (if the tool is metal): Wrap the pry tool in blue masking tape — or another type of tape — in order to minimize scratches to the car.
  • There are several retaining clips holding the door panel in place. Their locations are roughly outlined by the red circles.
  • You’ll find a notch in the door panel on the bottom of the door. This is where you should insert your door panel pry tool. You can also use a couple of flat-blade screwdrivers or a paint scraper in lieu of of a door panel pry tool, but you may accidentally damage your door panel’s paint.
  • Optional (if the tool is metal): Wrap the pry tool in blue masking tape — or another type of tape — in order to minimize scratches to the car.
Hier Übersetzung einfügen
