Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
4. Schritt
Insert the door panel pry tool into the notch found on the bottom of the door panel. Once fully inserted, pull towards you in order to disconnect the first retaining clip. The door panel should now be slightly looser on the bottom. Re-insert the pry tool on the bottom-right of the panel, and pull toward you to disconnect the second retaining clip.
  • Insert the door panel pry tool into the notch found on the bottom of the door panel.
  • Once fully inserted, pull towards you in order to disconnect the first retaining clip.
  • The door panel should now be slightly looser on the bottom. Re-insert the pry tool on the bottom-right of the panel, and pull toward you to disconnect the second retaining clip.
Hier Übersetzung einfügen
