Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Pry off the lens frame using a plastic opening tool. Remove the top three T6 screws of the front panel using a 1.5 mm screwdriver. Remove the three screws on the side of the lens using a Phillips #00 screwdriver.
  • Pry off the lens frame using a plastic opening tool.
  • Remove the top three T6 screws of the front panel using a 1.5 mm screwdriver.
  • Remove the three screws on the side of the lens using a Phillips #00 screwdriver.
  • Remove the front panel by pivoting the right side of the front panel outwards using a pair of tweezers.
    • As shown in the last image, the pivoting point is located above the lens.
Hier Übersetzung einfügen
