Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
4. Schritt
Remove the two black speaker screws shown in red circles in the first image using a Phillips #00 screwdriver. After unscrewing the screws from the previous step, lift out the speaker plate when it becomes loose enough. Open the multi-connector cover shown in the yellow square in the fourth image.
  • Remove the two black speaker screws shown in red circles in the first image using a Phillips #00 screwdriver.
  • After unscrewing the screws from the previous step, lift out the speaker plate when it becomes loose enough.
  • Open the multi-connector cover shown in the yellow square in the fourth image.
    • The multi-connector compartment is used to connect an AV cable to another device. The multi-connector has a waterproof cover and also allows the device to display pictures on a television screen.
  • The side panel that covers the multi-connector and the speaker can be detached by sliding the side panel off of the device.
Hier Übersetzung einfügen
