Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 3 übersetzen
Schritt 3
Using the plastic opening tool and spudger, carefully pry up the battery from the case. You should hear the adhesive ripping as you do this. Once the battery is no longer adhered to the case, detach the dongle that connects the battery to the motherboard.
  • Using the plastic opening tool and spudger, carefully pry up the battery from the case.
  • You should hear the adhesive ripping as you do this.
  • Once the battery is no longer adhered to the case, detach the dongle that connects the battery to the motherboard.
Hier Übersetzung einfügen
