Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Insert a Spudger (or pushpin) into the top notch of the rubber cover, located on the top of the phone. Press down and rotate the Spudger lifting the rubber cover. Remove and set cover aside. Note: This will reveal a screw. Five screws should now be visible.
  • Insert a Spudger (or pushpin) into the top notch of the rubber cover, located on the top of the phone.
  • Press down and rotate the Spudger lifting the rubber cover. Remove and set cover aside.
  • Note: This will reveal a screw. Five screws should now be visible.
  • Using a T6 Torx screwdriver, unscrew all 5 screws and carefully set them aside.
Hier Übersetzung einfügen
