Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 28 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
4. Schritt
Remove the single 2.3 mm Phillips screw securing the battery connector to the logic board. To reduce the risk of a short, you can insert a battery blocker or a modified opening pick to disconnect the battery. Slide the battery blocker underneath the battery connector area of the logic board, and leave it in place while you work.
  • Remove the single 2.3 mm Phillips screw securing the battery connector to the logic board.
  • To reduce the risk of a short, you can insert a battery blocker or a modified opening pick to disconnect the battery.
  • Slide the battery blocker underneath the battery connector area of the logic board, and leave it in place while you work.
Entferne die einzelne 2,3 mm Kreuzschlitzschraube #000, mit der der Batteriestecker am Logic Board befestigt ist.
Um das Risiko eines Kurzschlusses zu vermeiden, kannst du ein akkuisolierendes Plektrum benutzten, um den Akku zu trennen.
Schiebe ein akkuisolierendes Plektrum unter die Batteriesteckerstelle auf dem Logic Board, und lasse es dort während du arbeitest.
[* red] Remove the single 2.3 mm Phillips #000 screw securing the battery connector to the logic board.
[* icon_note] To reduce the risk of a short, you can useinsert a battery isolation[product|IF145-304-2|battery blocker|new_window=true] or a modified opening pick to disconnect the battery.
[* black] Slide athe battery isolation pickblocker underneath the battery connector area of the logic board, and leave it in place while you work.
