Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 9 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Locate the two switches toward the bottom corners of the device's back cover. Use your thumbs or fingers to push the two switches forward at the same time and detach the back cover from the device. Check to make sure the back cover has fully detached from the device. You should be left with two separate pieces: the back cover, and the device with exposed internal hardware.
Back Cover Removal
  • Locate the two switches toward the bottom corners of the device's back cover.
  • Use your thumbs or fingers to push the two switches forward at the same time and detach the back cover from the device.
  • Check to make sure the back cover has fully detached from the device. You should be left with two separate pieces: the back cover, and the device with exposed internal hardware.
Hier Übersetzung einfügen
