Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 6 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 3 übersetzen
Schritt 3
Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components. Pry the device open from the other side also if it does not fully disassemble from one side. Pry the device open from the other side also if it does not fully disassemble from one side.
  • Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components.
  • Pry the device open from the other side also if it does not fully disassemble from one side.
Hier Übersetzung einfügen
