Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
2. Schritt
The screen is connected to the device by a ribbon cable on the left side with the power button facing you. Do not try to completely separate the screen from the device yet, and be careful. Gently pry the screen loose using a plastic opening tool. If the screen doesn't easily come loose, more heating may be required
  • The screen is connected to the device by a ribbon cable on the left side with the power button facing you. Do not try to completely separate the screen from the device yet, and be careful.
  • Gently pry the screen loose using a plastic opening tool.
  • If the screen doesn't easily come loose, more heating may be required
Hier Übersetzung einfügen
