Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 6 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 4
Locate the second antenna connection toward the middle right area of the back panel. It is found in the corner where the red and yellow tabbed pin strips met. Remove the antenna connection using the same method done in the previous, top antenna removal step. Loosen the bottom metal cable grip (which pins down the cable) to separate the antenna from the motherboard entirely.
  • Locate the second antenna connection toward the middle right area of the back panel. It is found in the corner where the red and yellow tabbed pin strips met.
  • Remove the antenna connection using the same method done in the previous, top antenna removal step.
  • Loosen the bottom metal cable grip (which pins down the cable) to separate the antenna from the motherboard entirely.
Hier Übersetzung einfügen
