Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Englisch
Deutsch
Schritt 4
Use continuous downward pressure to keep the driver tip in contact with the screw. A limp grip or a lack of pressure will cause the driver to simply slip out of the screw head instead of turning the screw. A limp grip or a lack of pressure will cause the driver to simply slip out of the screw head instead of turning the screw.
  • Use continuous downward pressure to keep the driver tip in contact with the screw.
  • A limp grip or a lack of pressure will cause the driver to simply slip out of the screw head instead of turning the screw.
Übe gleichmässigen und kontinuierlichen Druck nach unten aus, damit die Spitze des Schraubendrehers immer im Schraubenkopf bleibt.
Ein schlaffer Halt oder ein zu geringer Druck führen dazu, dass der Schraubendreher einfacher aus dem Schraubenkopf rutscht, anstatt die Schraube zu drehen.
