Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Remove the following four screws that hold the base to the motherboard: One 1.5 mm Phillips #1 screw located near the center of the laptop.
  • Remove the following four screws that hold the base to the motherboard:
  • One 1.5 mm Phillips #1 screw located near the center of the laptop.
  • One 1.5 mm Phillips #1 screw located at the top, center, next to the metal guard.
  • This screw is concealed by a black wire running across the top of the laptop. You will have to move the wire to the right in order to remove the screw.
  • Two 1.5 mm Phillips #1 screws located next to the fan.
Hier Übersetzung einfügen
